Buy EcoFlow DELTA Pro Portable Power Station | 2*DELTA Pro + Double Voltage Hub | EcoFlow
Whole-Home Backup Kit: EcoFlow Smart Control Kit Whole-Home Backup Kit: EcoFlow Smart Control Kit Whole-Home Backup Kit: EcoFlow Smart Control Kit Whole-Home Backup Kit: EcoFlow Smart Control Kit Whole-Home Backup Kit: EcoFlow Smart Control Kit
USD $5,199.00
Hot
Hot
Regular price USD $5,199.00
Sale price USD $5,199.00 Regular price $7,498.00
-$2,299
Up to EcoCredits for cash deduction
Get up to $1,889.70 in rebates through the Residential Clean Energy Credit. Learn More >
Up to $1,889.70 in rebates
Amount 30% off
Claim By: December 31, 2032
Program: Residential
  • Rentals do not qualify.
  • Must be grid-tied.
Professional electrician installation required; installation fees for Smart Home Panel not included.
• Installation-free | Forget expensive and complicated systems, it’s easier than ever to prepare for blackouts with a plug-and-play design. Simply connect to your breaker panel via a power inlet box or transfer switch for instant home backup.
• Clean home backup alternative| Exchange noisy, high-maintenance gas generators for quiet and reliable home backup and convenient EV charging.
• Power almost everything | Already have two DELTA Pros? Get an extra Double Voltage Hub now and pair two units to hit the massive 7200W and 240V output to power your entire home, including high-wattage ones.
• Up to 1 week of power | Expandable capacity from 7.2 to 21.6 kWh with extra batteries, store energy and keep your critical circuits running for up to a week.
• Fast recharging between outages | With the signature X-Stream technology, ideal for fast charging between short outages.
Note:
1. 1x 1.5m NEMA L14-30P to L14-30R cable is included in this bundle to hook up the Double Voltage Hub into your home’s power inlet box.
2. The Double Voltage Hub requires two EcoFlow DELTA Pro units.
You Could Apply for 30% Tax Credit*, When You Install DELTA Pro as a Home Power Solution Learn more
USD $5,199 $7,498 -$2,299
All-in-one home backup power.
Simple, sustainable, and affordable whole-home backup power solutions with an output power of up to 7200W and a whopping 21.6kWh capacity for security and comfort. Easily chain together two DELTA Pros using the Double Voltage Hub and plug in to your breaker panel via an transfer switch or power inlet box. The solution provides a convenient home battery system without rewiring or running dangerous extension cables through home, and a customizable solar system.
Be prepared for any outages.
Stay ahead of the game, bring warmth and security to your family. Easily integrate your DELTA Pros and Double Voltage Hub to your home circuits via the transfer switch, selecting up to 6 circuits such as fridge, garage door, outlets in main living areas, light switches, etc. With DELTA Pro’s expandable capacity, enjoy peace of mind with up to 1 week of essential energy storage from 7.2kWh-21.6kWh with Extra Batteries.
Clean & silent power alternative.
Replace noisy, smoky generators with a silent and fume-free portable home battery solution. Unlike generators, these batteries are flexible to use both outdoors and indoors to run all your essentials during a blackout. And, with the help of solar energy, they can easily be recharged during an extended outage.
Power your entire home with 240V and 7200W.
Battery backup has never offered this kind of output. The Double Voltage Hub doubles the AC output to 7200W and 240V, so you can run 99% of all home appliances, including high-wattage ones like a clothes dryer or electric heater. Note: The Double Voltage Hub requires two EcoFlow DELTA Pro units.
Fast recharging between outages.
Fully recharge the DELTA Pro in 1.8 hrs with 240V outlets(3000W), 2.7 hrs with 1800W wall outlets. Ideal for juicing up the battery between short outages. EcoFlow’s X-Stream charging technology isn't just fast, it's safe too with EcoFlow's battery management system.
Customize your own solar system has never been this easy. Get limitless energy and save energy bills with solar panels. No sun, no wind, and a blackout hits? You’re still good. Lean on the Smart Generator as a last resort to charge your batteries.
See how real users think
Disclaimer
Effective date: Jan 1, 2023
