Buy EcoFlow DELTA Pro Portable Power Station | (Members-only) DELTA Pro + DELTA Pro Smart Extra Battery
EcoFlow DELTA Pro Portable Power Station EcoFlow DELTA Pro Portable Power Station EcoFlow DELTA Pro Portable Power Station EcoFlow DELTA Pro Portable Power Station EcoFlow DELTA Pro Portable Power Station EcoFlow DELTA Pro Portable Power Station EcoFlow DELTA Pro Portable Power Station EcoFlow DELTA Pro Portable Power Station EcoFlow DELTA Pro Portable Power Station EcoFlow DELTA Pro Portable Power Station EcoFlow DELTA Pro Portable Power Station EcoFlow DELTA Pro Portable Power Station EcoFlow DELTA Pro Portable Power Station
USD $2,299.00
Hot
Video
Hot
Regular price USD $2,299.00
Sale price USD $2,299.00 Regular price $4,997.00
-$2,698
Get up to $1,109.70 in rebates through the Residential Clean Energy Credit. Learn More >
Up to $1,109.70 in rebates
Amount 30% off
Claim By: December 31, 2032
Program: Residential
  • Rentals do not qualify.
  • Must be grid-tied.
  • *Please note that the eligibility for this tax rebate is subject to IRS's new PIN ASSIGNMENT REQUIREMENT and Q&A
Storm-ready Home Backup Power Sale!
Free RAPID (5000mAh) With $1,000+ Order
Free 220W Solar Panel With $3,000+ Order
Free 400W Solar Panel With $5,000+ Order
Ends in:
-Spend $1,000 or more in a single order to receive a EcoFlow RAPID Magnetic Power Bank (5000mAh), (valued at $69.99 USD).
-Spend $3,000 or more in a single order to receive a EcoFlow NextGen 220W Bifacial Portable Solar Panel (valued at $329 USD).
-Spend $5,000 or more in a single order to receive a EcoFlow 400W Portable Solar Panel (valued at $749 USD).
-Not applicable to flash sale items, recommended accessories, Power Kits, gift cards, app-only items, or members-only products.
-Only one promotional gift is allowed per order, per customer, and per address during the Promotion Period. Cannot combine with low-tier gift.
• 3.6-25kWh expandable capacity with DELTA Pro Smart Extra Battery
USD $599 USD $1,199
22.6% Conversion Rate | IP68
USD $1,599 USD $2,799
USD $359 USD $599
USD $359 USD $599
USD $599 USD $1,199
USD $359 USD $599
USD $359 USD $599
USD $359 USD $599
You Could Apply for 30% Tax Credit*, When You Install DELTA Pro as a Home Power Solution Learn more
USD $2,299 $4,997 -$2,698
Best-Selling DELTA Pro The prime choice of 286k worldwide homes
This state of-the-art high-capacity power station powers 286,000+ homes in over 100 countries. Become a proud DELTA Pro owner today and save big!
$2,199.00 $4,898.00
Enjoy solar energy with up to 50% savings
Fast charge with up to 23% conversion rate
Full charge with solar in as fast as 3.8 hr
Add To Cart
DELTA Pro + Transfer Switch
$1,999.00 $4,098.00
Enjoy clean and silent power alternative
Easy installation with completely pre-wired
Plug & play home backup solution
Add To Cart
First portable home battery designed for home backup.
Starts at 3.6kWh
Power for Any Situation.
From tailgate power to extreme blackouts that last for days on end, DELTA Pro offers a capacity of up to 25kWh, so you're covered for any situation.
All-Day Running Power
A single DELTA Pro unit packs 3600W AC output, expanded up to 4500W with X-Boost technology. Power 99.99% of heavy-duty devices at home, outdoors, or at work. You can even pair two units together to achieve 7200W.With its long-lasting power, even during power outages, your kitchen stays fully powered and worry-free.
With a DC-coupled EcoFlow Smart Generator, get up to 40% more efficient charging with less energy loss.
Simple, sustainable, and affordable whole-home backup power solutions with an output power of up to 7200W and a whopping 21.6kWh capacity for security and comfort. Easily chain together two DELTA Pros using the Double Voltage Hub and plug in to your breaker panel via a transfer switch. The solution provides a convenient home battery system without rewiring or running dangerous extension cables through your home.
A clean energy alternative.
Power your entire home.
With the Double Voltage Hub, DELTA Pro* provides unparalleled AC output of up to 7200W and 240V. Run 99% of all home appliances, even high-wattage clothes dryers and electric heaters, so you can keep your home running smoothly.
*Double Voltage Hub requires two EcoFlow DELTA Pro units.
Smart energy management.
Travel without limits.
EV backup charging solution.
Unleash your creativity.
Take energy on the go and get the creative juices flowing. Whether you're a filmmaker or want to work on the go, DELTA Pro's impressive output and large capacity can power all your equipment, ensuring a smooth workflow no matter where you are.
Power that means business.
How thick is the 2-meter-long (xx ft) Infinity Cable for DELTA Pro?
3+8 ports, power cable 10AWG, signal cable 22AWG.
How can I achieve a capacity of 25kWh?
To achieve 25kWh, you need to connect two DELTA Pro units using a Smart Home Panel and connect two Extra Battery packs to each DELTA Pro. This setup will provide 21.5kWh. If you also use our Smart Generator to charge the DELTA Pros, then 2 × DELTA Pro + 2 × Extra Batteries + 2 × Smart Generators, allows you to achieve 25kWh in a single charge.
What is the noise level of the DELTA Pro?
The DELTA Pro has a fan to keep its battery cool. At a 1-meter (xx ft) distance, the noise level ranges from 48 to 60 dB (between normal conversation and an office environment). The noise level varies depending on the wattage flowing in or out of the battery and temperature.
What are the output specifications of the DELTA Pro?
DELTA Pro Output Specifications
DELTA Pro supports five output types: AC, USB, car charger, DC5521, and Anderson port, providing 15 output ports in total.
AC Output (Pure Sine Wave)
Quantity: 4 (4 × 20A)
Rated Power: 3600W (Peak: 7200W) Voltage: 220V, AC 50/60Hz
Smart Inverter System: X-Boost supports 3600W-4500W devices*
Anderson Port
Quantity: 1
Specification: 12.6V, 30A
USB-A Ports
Quantity: 2
Specification: 12W, 5V, DC 2.4A
USB-A Fast Charging Ports
Quantity: 2
Specification: 18W, 5-12V, DC 2.4A (max)
USB-C Ports
Quantity: 2
Specification: 100W, 5-20V, DC 5A (max)
Car Charger Port
Quantity: 1
Specification: 126W, 12.6V, DC 10A (max)
DC5521 Outlet
Quantity: 2
Specification: 37.8W, 12.6V, DC 3A
Note: The car charger and DC5521 ports share power, with a maximum combined output of 127W.
Can the Extra Battery directly charge DELTA Pro?
Yes.
When using the Double Voltage Hub, do I have to turn on the DELTA Pro first? Can the Double Voltage Hub directly power on the DELTA Pro?
Yes, the DELTA Pro needs to be turned on first. The Double Voltage Hub controls the AC output switch but cannot directly power the DELTA Pro on or off.
What is the peak power of the DELTA Pro Double Voltage Hub? Is there a duration limit?
The peak power can reach 9000W, but peak power duration is usually very short, lasting only tens of milliseconds.
What is the standby power consumption of the DELTA Pro?
When the AC output button is turned on, standby power consumption is approximately 30W.
Does it support dual charging (AC charging and DC charging)?
Yes, AC and DC charging can occur simultaneously, with a maximum input of 2200W.
Why is the DELTA Pro unable to charge/power my devices?
1.If charging from AC output ports, ensure the AC output switch is turned on. The same applies to DC output ports.2.If the AC or DC power switch is on but charging is still not working, check if the DELTA Pro's output power matches your device's power requirements.3.If your device's power is below 10W, the AC output switch will turn off after 12 hours because the detected power is considered negligible. In this case, manually turn the AC output switch back on.4.If the screen displays an overload warning, the charging power is too high. Try the following: Turn off and let it cool for a while. Use a lower-power device. If the overload persists, power off and cool the unit for 30 minutes before restarting. If the issue continues, contact customer support.
Is the DELTA Pro compatible with the Smart Home Panel 2?
Yes, but you need a Double Voltage Hub to connect to the Smart Home Panel 2's 5+8 ports.
Can I use a DELTA Pro unit instead of a DELTA Pro Smart Extra Battery to connect to another DELTA Pro? If I want to connect two DELTA Pro units, what do you recommend?
No, the main unit must work with an Extra Battery for capacity expansion.If you want to connect two DELTA Pro units, consider using a Double Voltage Hub based on your actual needs.
3600Wh
Extra Battery
4500W
USB-A Fast Charge
Car Power Output
12.6V, 10A, 126W Max
DC5521 Output
Anderson Port
12.6V, 30A
AC Charging Input
Solar Charging Input
1600W Max, 11-150V, 15A Max
Car Charging Input
Support 12V/24V battery, 8A
Connection
Wi-Fi, Bluetooth
Approx. 99lbs/45kg
Dimension
Disclaimer
Effective date: Jan 1, 2023
Stay in the Loop & Save More!
Price Drop Alerts
Cost Savings
Whole-Home Backup
Intelligence Solutions
Thank you for subscribing!
