EcoFlow DELTA Pro Ultra | Whole-Home Backup Power | (Members-only) DELTA Pro Ultra + 2 × 400W Rigid Solar Panels
EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated) EcoFlow DELTA Pro Ultra Whole-Home Backup Power (UL 9540 Certificated)
USD $4,999.00
Regular price USD $4,999.00
Sale price USD $4,999.00 Regular price $7,097.00
-$2,098
Get up to 30% Off in rebates through the Residential Clean Energy Credit. Learn More >
Save 1454.7 in rebates
Amount 30% off
Buy on or after: January 1, 2023
Claim By: December 31, 2032
Program: Residential
  • Rentals do not qualify.
  • Must be grid-tied.
  • *Please note that the eligibility for this tax rebate is subject to IRS's new PIN ASSIGNMENT REQUIREMENT and Q&A
Storm-ready Home Backup Power Sale!
Free RAPID (5000mAh) With $1,000+ Order
Free 220W Solar Panel With $3,000+ Order
Free 400W Solar Panel With $5,000+ Order
Ends in:
-Spend $1,000 or more in a single order to receive a EcoFlow RAPID Magnetic Power Bank (5000mAh), (valued at $69.99 USD).
-Spend $3,000 or more in a single order to receive a EcoFlow NextGen 220W Bifacial Portable Solar Panel (valued at $329 USD).
-Spend $5,000 or more in a single order to receive a EcoFlow 400W Portable Solar Panel (valued at $749 USD).
-Not applicable to flash sale items, recommended accessories, Power Kits, gift cards, app-only items, or members-only products.
-Only one promotional gift is allowed per order, per customer, and per address during the Promotion Period. Cannot combine with low-tier gift.
Recommended
EcoFlow Installation Service Installation Service for Smart Home Panel 2 Turnkey Installation Service
USD $2,000
By selecting this service, you agree to the Installation Service Terms and Conditions.
USD $2,000
USD $2,000
USD $2,000
Ecoflow Turnkey Installation Service. Learn More
USD $2,000
USD $2,000
USD $2,000
USD $2,000
You Could Apply for 30% Tax Credit*, When You Install EcoFlow DELTA Pro Ultra as a Home Power Solution Learn more
USD $4,999 $7,097 -$2,098
-The only portable power station certified to both UL1973 and UL9540, offering extreme reliability for home use.
-6kWh-90kWh capacity, whole house backup for weeks with comfort
-Auto-switchover, prolonged backup, and energy bill savings with EcoFlow Smart Home Panel 2
-5 Charging Options, even plan B has a plan B
Battery automatically starts self-heating if the temperature is lower than 32℉, allowing the battery to run as normal
*Note: The DELTA Pro Ultra Inverter package does not include a connection cable . To connect a second inverter to SHP2, please purchase the connection cable separately.
Smart Home Panel 2 requires installation before use, and the specific fee will depend on the assessment, and only 'EcoFlow DELTA Pro Ultra + Smart Home Panel 2 + Installation' includes installation services.
The most powerful whole-home backup solution.
Month-long power security.
6-90kWh Capacity
5.6kW-16.8kW Solar Input
Flexible Solar Systems
Rigid Solar System
EcoFlow DELTA Pro Ultra works seamlessly with existing rooftop solar panels, replacing sensitive solar inverters prone to failure. Working in tandem with EcoFlow Smart Home Panel 2, maximize the value of your solar power and cut a chunk of change off your energy bill.
*This information is intended for users who have not installed a solar inverter.
Always in charge
With a Generator or EV pile
Peace Of Mind With An Advanced Design.
EcoFlow X-Cooling
Boost Performance with BMS
Our state-of-the-art LFP tech and advanced battery management system (BMS) regulates vital data, ensuring the safety, longevity, and high performance of EcoFlow DELTA Pro Ultra.With each battery offering a cycle life of 3500+, you'll get years of use before capacity drops to 80%. Even then, it keeps powering on.
290V high voltage tolerance
6144Wh, 102.4V⎓60A
30kWh (5 x DPU Battery)
AC Continuous Output
7200W
Expanable Capacity(System*)
90kWh (15 x DPU Battery)
AC Surge Output
10.8kW
Scalability(System*)
21.6kW
IP Rating
IP54
Battery Cycle Life
UPS
DC Output
12.6V⎓30A, 378W Max
AC Output Socket (Backup UPS)
2 x 120V, 20A Max per port
1 x 120V/240V, 30A Max
USB-A
AC Output Socket (Online UPS)
1 x 120V, 30A Max
USB-C
AC Input
Solar Charging Input
Total 5600W, 2 ports
Inverter Dimension
Inverter Net Weight
31.7 kg (70 lb)
Battery Dimension
Battery Net Weight
50.7 kg (111.8 lb)
5-year warranty
Connection
Bluetooth & Wi-Fi & 4G
Discharging temp
-20°C to 45°C | -4°F to 113°F
Charging temp
Storage temp
Hassle-Free bundle Installation Terms & Conditions
Installation Conditions
2. If a customer's house is too large, resulting in excessive wiring and undervoltage, there may be a risk that the NEC regulations will not be met, and the installation will be prevented.
3. In the event of unforeseen circumstances that may prevent installation, EcoFlow reserves the right to determine the final feasibility of installation.
Installation Service Package ONLY covers the installation labor costs.It does not include wiring the EcoFlow Power Station to solar panels or PV systems. If the customer requires the installation to include wiring to solar panels or PV systems, the electrician reserves the right to refuse to take order.
The installation service excludes:
a. Additional material and labor costs due to excessive distance or incompatibility between the existing circuit breaker and Smart Home Panel 2.
c. The electrician's on-site assessment fee, which can be waived if the circumstance has been assessed by the electrician to be suitable for installation and the customer does not request for refund of the installation service fee.
The above extra costs and fees shall be subject to the actual quote from the electrician. Customers are responsible for directly paying the electrician for any extra costs incurred. EcoFlow reserves the right to final interpretation of the installation service fee.
By agreeing to EcoFlow's installation services, you consent to the collection and processing of personal information necessary for completing the service. This may include, but is not limited to, your name, address, contact information, and any relevant details related to the installation. We will handle your personal information in compliance with applicable data protection laws and regulations and will only use it for the purpose of fulfilling the installation service. Please refrain from directly providing your personal information to the electrician during the installation process, otherwise you will be responsible for any loss or damage caused by the disclosure of such information.
3. Should a customer opt for our installation service and then decide to return the Smart Home Panel 2 due to dissatisfaction after installation, the paid installation fee cannot be refunded. Additionally, the customer will be responsible for any costs associated with the removal of Smart Home Panel 2.
4. The installation service does not include any cleaning or removal of debris generated during the installation process. Residents are responsible for managing and disposing of all trash and debris resulting from the installation.
5. Any holes or modifications made to the premises during the installation are considered normal and necessary for the proper completion of the service. The installer shall not be held liable for any unavoidable damages or alterations made to the premises during the installation process.
7. Any product issues or defects resulting from installation by an unauthorized installer shall be the sole responsibility of the resident. The resident shall bear full responsibility for any after-sales service or repairs needed due to such unauthorized installations.
Stay in the Loop & Save More!
Price Drop Alerts
Cost Savings
Whole-Home Backup
Intelligence Solutions
Thank you for subscribing!
