EcoFlow RIVER 2 Max Solar Generator (PV160W) | RIVER 2 Max + 1*160W | EcoFlow
EcoFlow RIVER 2 Max Solar Generator (PV160W) EcoFlow RIVER 2 Max Solar Generator (PV160W)
USD $649.00
Regular price USD $649.00
Sale price USD $649.00 Regular price $918.00
-$269
Up to EcoCredits for cash deduction
  • Generates up to 1.2kWh daily.
  • A 1000W AC output with X-Boost.
  • Lightweight and travel-friendly at 13.2 lbs.
  • A high conversion rate guarantees a fast solar charging speed: 0-100% in 4 hours (1 set).
  • LiFePO4 battery and IP68 dust and water resistance.
  • Smart remote control with EcoFlow app.
  • 5-year warranty for RIVER 2 Max and 12-month warranty for 160W Portable Solar Panel.
**RIVER 2 Max and 160W Portable Solar Panel will be shipped separately.
Shipment services to Alaska, Puerto Rico, and Hawaii are temporarily suspended.
USD $649 $918 -$269
Power. Never Been This Easy
Charge 0-100% in 1 Hour
Fastest charging speeds ever.
RIVER 2 Max beats the industry charging speed standard, fully charging in only 60 minutes.. That's 5x faster than other portable power stations on the market and 38% quicker than previous generations. Fully charge RIVER 2 Max while you pack your bags, so you'll always be ready for a last-minute trip.
LiFePO4 Battery Chemistry
With upgraded long-lasting LFP battery chemistry at its core, charge and empty RIVER 2 Series over 3000 times. That's pretty much 10 years of everyday use1 and 6x longer than the industry average. With LFP cells, RIVER 2 Series is safe, durable, and highly efficient, even in warm temperatures.
The first power station that's TÜV Rheinland certified.
RIVER 2 Series is a cut above the rest as the first portable power station in the world to get certified. With it's high safety standard, the TÜV Rheinland certification means the security and reliability of RIVER 2 Series is guaranteed.
5-year Warranty
Our state-of-the-art Battery Management System (BMS) constantly monitors the voltage, current, and temperature of RIVER 2 Series with multiple aspects of protection, extending its life to the max.2
4 Ways to Charge
Charge anywhere.
With 4 different ways to top up the RIVER 2 Series, there's a recharge option no matter what.3 From fast AC to in-car charging when you're on the go.
AC ChargingCar ChargingSolar ChargingUSB-C Charging
Why not harness renewable energy while you camp or head off on a trip? Plug in a couple of portable solar panels to fully recharge off-grid in as fast as 3 hours.
X-Boost Up to 1000W
Small size. Big power.
RIVER 2 Max has an AC output of up to 500W. Need to power a vacuum cleaner or sandwich maker? Crank it up to 1000W with X-Boost mode to run up to 80% of essential appliances.
Lightweight at only 6 kg
With a compact portable design, taking travel-friendly power off-grid has never been this easy. With a light-weight that's 22% lighter than the previous generation, RIVER 2 Max is ready to power all your outdoorsy escapades, from boondocking to BBQs at the beach.
<30ms EPS Auto-switch
Ultra-fast home backup switchover.
With a switchover speed of less than 30ms, you won't even know the power was down. Use RIVER 2 Series as an emergency power supply for outages to keep essentials running from a light machine to your fish tank.
EcoFlow App
Control at your fingertips.
Use the EcoFlow app to control and monitor RIVER 2 Series, even from afar. View charging levels, customize settings, and adjust charging speeds, all from the convenience of your phone.
Learn More >
Power. Anywhere. Anytime.
1. RIVER 2 Max2. AC Charging Cable3. Car Charging Cable 4. DC5521 Connection Cable5. Quick Start Guide6. 160W Solar Panel7. Solar Charging Cable
*The solar charging cable is sent together with the solar panel.
512Wh
Approximately 13.4lbs
10.6 x 10.2 x 7.7inches
AC Input
100-120V 50Hz/60Hz, 660W Max
Solar Input
11-50V, 13A, 220W Max
Car Input
12V/24V, 8A, 100W Max
USB-C Input/Output
5/9/12/15/20V, 5A, 100W Max
120V 50Hz/60Hz, 500W (Surge 1000W)
DC Output
12.6V, 10A/3A/3A, 126W Max
5V, 2.4A, 12W Max
DC5521 Output
12.6V, 3A, 36W Max
Cell Chemistry
App Control
Wi-Fi, Bluetooth
Discharge Temperature
14°F to 113°F/-10°C to 45°C
Charge Temperature
32°F to 113°F/0°C to 45°C
Optimal Operating Temperature
68°F to 86°F/20°C to 30°C
Storage Temperature
14°F to 113°F (68°F to 86°F is best)/-10°C to 45°C (20°C to 30°C is best)
1. Using RIVER 2 Max six times a week, 3000 full 100% cycles will last 9.6 years until it drops to 80%.
3. When charging and discharging at high wattage, RIVER 2 Max may make a noise up to 62db.
